I am using the TPS7A4001 in an avionic project and the LDO (TPS7A4001) does not work just 3 degrees below it´s minimum operation temperature of - 40°C @ -43°C.
I did not expect, that this LDO is the first device in my controller that stops working at low temperature.
Is this a known issue / bug / problem of the LDO?
Thanks in advance for your answers.
Regards Lars
