Hi Sir,
On the TLV733P-Q1 spec, the RθJA value is lower than RθJC, but typically RθJA should higher than RθJC.
May i have your help to advise if there is any reason to cause this? or this is a typo?
Patrick.
Hi Sir,
Patrick.
Hi Patrick,
Your understanding is correct, but in TLV733P-Q1 datasheet has two values of RθJC; RθJC(top) and RθJC(bottom) where RθJC(bottom) is lower than RθJA. Some designer recommend using a heat sink (in designs with thermal margin) when only a single surface is used for heat removal that's why we have two RθJCs, please refer to Semiconductor and IC Package Thermal Metrics document paragraph 2.4 for further explanation.
Haidar
