Other Parts Discussed in Thread: TPS7B63-Q1
Team,
I'm FAE in TI Korea Automotive Team.
There is reset issue that LDO resets during low voltage input test down to 4V. Since TPS7A6350-Q1 resets when output voltage goes down to 4.65V, customer cannot meet cold-cranking requirement from OEM. Is there any solution to change reset voltage or disable reset function?
I found TPS7B6350-Q1 has adjustable reset voltage function with PGADJ pin. It looks it totally can replace RESET function in TPS7A6350-Q1. Do you think this device can replace TPS7A6350-Q1?
Please let me know if you have any idea.
Ian Lee
