As to fixed version of TLV1117, whether it uses inner divider resistors or it has different inner reference?
if customer wants to use TLV1117-50 5V fixed output LDO as 12V output voltage LDO, how to realize it? could they add one resistor between ADJ/GND pin and output GND as shown in below picture? or use external feedback divider resistors as 5V inner reference between OUT pin and ADJ/GND pin?
if we use inner divider resistor in fixed version TLV1117, what is value of inner divider resistor and how to calculate external resistor with adjust output voltage?
Thanks in advance.
Yang
