Other Parts Discussed in Thread: TPS709
Dear Team,
My customer has been using TLV70433 and they have a problem with noise immunity test.
At frequencies higher than 150MHz in radiated immunity test, the output regulation get worse if the input of the device is supplied from an SMPS stage. However, if they keep the SMPS running, but the input of the device is supplied from a battery, then there is no issue.
What could be the problem here?
Caglar
