• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » Controller for near kw power rating interleaved buck
Share
Non-Isolated DC/DC
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
ilker sahin
Posted by ilker sahin
on Apr 06 2012 09:23 AM
Prodigy20 points
Hi
I'm supposed to build a buck type interleaved converter with specs roughly 100V input 36 V output with total power near kW level. I could not find a controller IC aimed for this kind of converter.
TPS4009 seems a very good solution however it is specifically written in its datasheet that this product aims low power high current applications.
How come a controller dictate input output voltage levels and power of a converter? Its duty is mainly create an error signal, amplify it accordingliy and produce duty cylce, isn't it? Or, are the voltage values i see recommended for IC supply, i.e can i use this controller in a higher rating converter with an auxillary converter dedicated for feeding IC? Will it be okay if i take the output voltage information with a divider then feed it to the IC? Or, is there any other solution?
I appreciate any comment or help
Thank you
interleaved buck TPS4009
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Na Kong
    Posted by Na Kong
    on Apr 08 2012 22:27 PM
    Verified Answer
    Verified by ilker sahin
    Genius16675 points
    Hi Ilker,
    The major concern for using TPS40090 for high voltage, high current application is how to feed the high output voltage into the remote sense amplifier and current sensing signal into the amplifier which is only designed for 4V max common mode voltage.
    If remote sense is not necessary, you may consider not using it by connecting the FB directly to the output voltage divider.
    For current sensing, higher output voltages can be supported by adding a resistor divider between the switch nodes and the output voltages, and ground.  This reduces the common mode voltage levels seen by the controller’s current sense inputs, but also reduces the differential sense current and add some additional error to the phase balancing.  Because of this, 0.1% accuracy resistors are recommended in the divider.
    Na
    Na Kong
    Applications
    DC Solutions
    Power Management
    Texas Instruments
    TPS40090
    Report Abuse
    • Reply
  • ilker sahin
    on Apr 09 2012 06:06 AM
    Prodigy20 points
    Thank you
    Report Abuse
    • Reply
  • William Friesen
    Posted by William Friesen
    on Aug 22 2012 19:58 PM
    Intellectual980 points
    Na,  I also would like to use the TPS40090 as a higher voltage buck.  My supply output is 21vdc.
    I plan to use a differential amplifier (opa235) to subtract out the 21 volt offset.
    Do you think that I can get by with a simple opamp or do I need to look for an isolating opamp?
    Will
    TPS40090
    Report Abuse
    • Reply
  • Na Kong
    Posted by Na Kong
    on Aug 26 2012 16:07 PM
    Genius16675 points
    Hi William,
    The common mode input voltage will be 21 V. I don't think OPA235 can allow this high input voltage. You may also consider using resistor divider to lower down the common mode voltage for current sensing signals.
    Na
    Na Kong
    Applications
    DC Solutions
    Power Management
    Texas Instruments
    TPS40090
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
