• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » TPS61030 draws high current after being touched
Share
Non-Isolated DC/DC
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Raghu Gopala Rao
Posted by Raghu Gopala Rao
on Apr 09 2012 02:46 AM
Prodigy65 points
I am using TPS61030 IC in buck boost application. The IC was working fine for 3-4days continuously  and when the engineer touch the thermal pad  of the IC from back side the IC failed.
The currently drawing from the IC is  just 700mA.
pls note: while accessing the board Engineer was wearing wrist strap and it was grounded properly.
what could be the issue. out of 8 boards 2 boards got failed.
Raghu
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Glaser
    Posted by Chris Glaser
    on Apr 09 2012 08:16 AM
    Guru60745 points
    Thank you for using the forums.  I would encourage you to put more information in your subject lines.  A better title for this post would be "TPS61030 draws high current after being touched".  'Issue' is a very broad term that encompasses most of the posts on these forums.
    If the board that the TPS61030 was on and its ground was not at earth potential, then touching it with something at earth potential still applies an ESD shock due to the voltage difference between the different nodes of this circuit.  You will need to see if this is a realistic situation in your end equipment and protect your system accordingly.
    Also note that the TPS61030 is not a buck boost converter.  The TPS63020 and TPS63060 are buck boost converters that may be better suited to your application.
    tps61030
    Report Abuse
    • Reply
  • Raghu Gopala Rao
    on Apr 12 2012 01:17 AM
    Prodigy65 points
    I am sorry for the for creating confusion. We do require boost only. So TPS61030 holds good for our design.
    I checked the design and currently we are using DC Power supply for testing purpose,So our ground and earth potential are same.
    Still if i touch the IC it will fail.And once i replace the IC and and touch the IC some time it fails and some time it is working fine. We do have a ESD protection device for the circuit and it will be battery operated device.
    Any other things need to take care, i am attaching the schematic also for your reference.
    After generating 5V the out put is also connected with 3.3volts Linear regulator and 4.7volts low drop out regulator
    Raghu
    Report Abuse
    • Reply
  • Chris Glaser
    on Apr 12 2012 08:07 AM
    Guru60745 points
    Thank you for attaching your schematic.  It looks reasonable except for the ferrites between the grounds.  We recommend connecting the grounds together directly.  Voltage offsets between them can cause issues.  You might rerun this test with the grounds tied directly together.
    Every power supply in our lab has isolated output terminals.  A few of our power supplies have a third terminal for earth ground but this is not normally connected.
    In any case, you will need to evaluate if your end customer (who is not grounded with an ESD strap) will be able to touch the IC and provide an ESD shock.  If they can, you will need to protect against this.  In most end equipments I have seen, the customer cannot touch the PCB at all.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
