• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » LM3489 Current limit operation
Share
Non-Isolated DC/DC
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Martin Novotny
Posted by Martin Novotny
on May 07 2012 02:49 AM
Prodigy50 points
lm3489 buck controller has an internal 5.5uA current source that vary from 3uA to 7uA (lm3489 datasheet). What function is current source of (ie. what causes the current change 3uA-7uA)? If I measure for example 5uA current can I assume this current is relatively stable and vary only with temperature approximately in range 4,8uA to 5,2uA(datasheet) or even this measured source(5uA) can vary from 3uA to 7uA?
Thanks.
LM3489
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Vijay Choudhary86929
    Posted by Vijay Choudhary86929
    on May 07 2012 11:27 AM
    Expert3630 points
    What current are you talking about Martin? Can you write the spec name? Usually internal currents vary becasue of multiple things including process and temperature.
    Report Abuse
    • Reply
  • Min Chen
    Posted by Min Chen
    on May 07 2012 11:59 AM
    Prodigy310 points
    Hi Martin,
    I guess you were referring to the current limit ADJ current. There is a typical performance curve of the ADJ current vs. temperature on the page 5 of the datasheet. That can give you some idea of how ADJ current varies with temperature and VIN.
    Min
    Report Abuse
    • Reply
  • Martin Novotny
    on May 09 2012 04:27 AM
    Prodigy50 points
    I am talking about the current limit ADJ current (ICL_ADJ) as mentioned Min Chen. In the graph (page 5 of the datasheet) the current vary approximately within interval 5,2uA - 5,7uA but the ICL_ADJ is characterized by 3uA - 7uA (page 3 min and max value). I need to set the current limit to 2A - 2,5A, but it seems if the ICL_ADJ vary 3uA - 7uA the current limit vary 2A - 4,6A. I need higher accuracy. It is possible with LM3489? Is the min and max value (3-7uA) given only by production and then the ICL_ADJ dont vary so much and vary only as shown in the graf (page 5, Current Limit ADJ Current vs Temperature) ?
    Report Abuse
    • Reply
  • Min Chen
    Posted by Min Chen
    on May 09 2012 16:42 PM
    Prodigy310 points
    Hi Martin,
    The min, max limits in the EC table have considered lot variations, test guard bands, statistical correlation etc.
    Below are some trip-temp characterization data. Please note that these are just for reference only and won't be guaranteed by the production.
    Test Name
    Units
    Temp (deg C),      TA=TJ
    Avg
    Min
    Max
    Current Llimit ADJ current source
    uA
    25
    5.63868
    5.03
    6.13
    125
    5.39723
    4.98
    5.76
    -40
    5.56205
    4.69
    6.150
    Report Abuse
    • Reply
  • Martin Novotny
    on May 10 2012 02:13 AM
    Prodigy50 points
    Hi Min Chen,
    my english is poor and probably I cannot explain the issue well. I will ask you a different way... I produce DC/DC with LM3489 and I set the current limit circuit (figure 5 on page 10) to limit 2A using ideal resistor Radj and Rcs. When I test the DC/DC first time I just measure limitation of 2A. Then I provide the DC/DC to customer that will use DC/DC in stable temperature 25°C, what min, max value of limited current can I guarantee?
    Report Abuse
    • Reply
  • Min Chen
    Posted by Min Chen
    on May 10 2012 11:51 AM
    Prodigy310 points
    Hi Martin,
    If you are making mass production, it is important to include sufficient margin in your design to accommodate parameter variations.  We cannot guarantee the spec limits different from the datasheet.  Sometimes, additional screening can be applied in the production to guarantee tighter spec limits. However that is per customer's request, requires a special procedure and extra cost.
    Hope this helps.
    Min
    Report Abuse
    • Reply
  • Martin Novotny
    on May 14 2012 01:08 AM
    Prodigy50 points
    Hi Min,
    I am not making mass production, I am making only one prototyp needing set 2A-2.5A limitation but with current source 3-7uA is not possible. I only wanted to know if I set this one prototyp to 2A limitation and I measure the current source has for example 5uA whether the current source can change over the whole specified range 3-7uA or change aproximatley only with temerature.
    Report Abuse
    • Reply
  • Min Chen
    Posted by Min Chen
    on May 14 2012 10:55 AM
    Verified Answer
    Verified by Martin Novotny
    Prodigy310 points
    Hi Martin,
    The ADJ current limit of an individual unit  varies mainly with the temperature. If you have tested the current limit of your prototype under the required operating conditions, customer should expect the similar results under the same operating conditions.
    Min
    Report Abuse
    • Reply
  • Martin Novotny
    on May 15 2012 10:42 AM
    Prodigy50 points
    Hi Min,
    that is what I need "Current limit varies mainly with temperature". Thank you very much!
    Martin
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
