• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » TPS61220 boost converter output current too low
Share
Non-Isolated DC/DC
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Victor Titov
Posted by Victor Titov
on May 07 2012 16:11 PM
Prodigy110 points
Hello everyone!
I have built a boost converter based on TPS61220 to power a circuit from a battery. I have been testing the converter alone and encountered a problem.
With input voltage of 3.7 V and output voltage of 5.5 V, the datasheet specifies I would get output currents up to slightly below 200 mA (the spec is actually for 5 V output). However, my converter provides only 11 mA, and increasing the load causes the output voltage to drop. This is not enough for me.
I have examined the input and output voltages - the ripple is no more than 40 mV at the input and 50 mV at the output. I have also looked at the inductor current, and saw the strange behavior there: the converter operates in short bursts. The bursts last for no more than ~15 switching cycles, followed by quite long periods of idling. This would have been OK for low loads, but this also happens at overload. The bursts themselves look good, with clean sawtooth-like inductor current peaking at around 300 mA.
 I have tried to increase input capacitance, with veery slight improvement. I have replaced the IC with another one, and still get the same results.
boost converter TPS61220 5V from 2.5V Iout too low
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Victor Titov
    on May 07 2012 18:38 PM
    Prodigy110 points
    Some progress in understanding. This burst-mode operation seems to be a startup mode. And with output voltage set to 5.5 V, the IC refuses to leave sturtup. If I set output voltage to 5.0 V by changing feedback divider, the problem goes away. I will explore this further since I need slightly more than 5 V to be able to smooth out the supply with an LDO. I should point out that in the datasheet, 5.5 V is included into recommended output voltage range (although it is exactly the maximum recommended). And even with 5.0 V output, the problem is still not over. The IC does not leave this burst-mode until the output voltage comes close to 5 V (the datasheet specifies the threshold of 1.8 V, which at 3.7 Vin is definitely overcome thanks to built-in diode). So it looks like the datasheet is wrong twice. It is actually more likely I am wrong...I feel I am right however. If someone could confirm my findings...
    Report Abuse
    • Reply
  • Chris Glaser
    Posted by Chris Glaser
    on May 08 2012 08:09 AM
    Guru59335 points
    This is indeed odd.  The part can output 5.5V at much higher currents.  Could you attach your schematic and board layout?
    Report Abuse
    • Reply
  • Victor Titov
    on May 10 2012 08:38 AM
    Prodigy110 points
    Please follow the link: https://plus.google.com/photos/105822372665226114142/albums/5739898425366521057 I was absolutely sure I had provided this link in the first post.
    Report Abuse
    • Reply
  • Chris Glaser
    on May 10 2012 09:38 AM
    Guru59335 points
    Thanks for sharing this.  You might want to order the EVM, which has already been built and tested, to evaluate your circuit.
    The layout states that there are two ceramic input and output caps but I only see one in the photo.  Did you stack the caps or is there just 1 there?  The datasheet recommends ceramic caps for both input and output.  The 6.8uF would work but just the 0.1uF may not.  I would also recommend removing that giant tantalum on the output and seeing if that helps things.
    You also might have noise getting into your FB resistors or have switching currents running through them.  This would explain things.  You might try reducing their values to 10k and 1k and seeing if this helps.  Or take the 10k resistor (lower resistor) and stand it up (tombstone it).  Then, run a wire from its ground right back to the IC's ground pin.
    TPS61220
    Report Abuse
    • Reply
  • Victor Titov
    on May 10 2012 12:55 PM
    Prodigy110 points
    Chris Glaser
    I did stack them. Initially there were only 0.1uF ones, and I soldered 6.8uF on top in attempt to fix the problem. Gained 1 mA - not much.
    Chris Glaser
    Chris Glaser
    I'll try. Thanks!
    Report Abuse
    • Reply
  • Victor Titov
    on May 11 2012 18:45 PM
    Prodigy110 points
    Results.
    "Removing giant tantalum" - does not help (causes extreme output ripple 1.5Vp-p). Placing 47uF aluminium electrolytic instead - simply does not help either.
    "take the 10k resistor (lower resistor) and stand it up (tombstone it). Then, run a wire from its ground right back to the IC's ground pin." - No difference.
    Reducing resistors - well, I didn't do that. Instead, I have placed 1K-potentiometer in parallel to the divider. It did not change the behavior at 5.5Vout, but it allowed extra experimentation.
    What I have found is that as I turn the voltage up (under 68 Ohm load), everything is good until I reach a value of about 5.15V. After that, the output voltage snaps to 4.8-5V and remains there, more or less independent of load. Next, as I turn the pot backwards (to lower the output voltage), at some point the output jumps up to c.a. 5.0 V and starts to respond to the rotation. So, it appears I was wrong about the startup mode, it looks more like overvoltage protection mode.
    The snap voltage (5.15V) depends on the temperature of the IC (or something else?). E.g. if I keep the converter under load for some time, the snap voltage increases to 5.35V. If I further heat the IC with hot air gun to 50°C, the snap voltage reaches 5.9 V. That is, at 50°C the converter works perfectly well for me.
    Without load, the output voltage can be increased up to 7.2V.
    I have also captured the startup of the converter under load, and noted interesting behavior. It starts up correctly, gaining 5.5V successfully, and begins to regulate. But soon afterwards, the output voltage drops to that damned 4.8-5V. The duration of good regulation is somewhat random, attaining times from about 10 ms to more than 0.4 s.
    I have added the captured plot to the album (please follow the link in the post number 4).
    Again, this looks like overvoltage protection comes into play.
    PS. For now, I am satisfied with the converter at 5.1V output. I will change the divider accordingly and move on to more essential parts of my project. Although the original problem remains unsolved, I have to move on. So, should I mark the question as answered?
    Thank you very much for your help!
    Report Abuse
    • Reply
  • Chris Glaser
    on May 14 2012 08:12 AM
    Guru59335 points
    It does sound like noise is getting into the FB pin and we would need to see more waveforms to be sure.  But if you have a solution you are happy with, then go with it.
    Report Abuse
    • Reply
  • Victor Titov
    on May 14 2012 10:59 AM
    Prodigy110 points
    I am sorry for emotions, but what else can be done to reduce that noise? The layout is almost as compact as I can make it, and FB is quite far from the noisy L-pin net. It shouldn't be that sensitive!
    By the way, I have also tried to short FB to ground right at the IC (the pins are adjacent, I had sticked something metallic in between). Doing so under load does not change the output voltage (or makes it jump to 4.8-5V if the one set is lower). So I really do not think that noise being fed into FB is the cause of the problem.
    Can you tell me the list of the waveforms you'd like to see?
     PS. Does anyone know, how tolerant is TPS61220 to soldering by hand? I haven't found anything in the datasheet on this. I have soldered it with a fine tip at 250°C, and for some pins it took me two or even three attempts to get it right.
    Report Abuse
    • Reply
  • Chris Glaser
    on May 14 2012 12:24 PM
    Guru59335 points
    Let's leave the profanity out of these public forums.
    The device is able to be soldered by hand.  We make EVMs that come pre assembled with a tested working circuit.  You can simply change one of the feedback resistors to make it output 5.5V.
    You would need to look at Vin, Vout, L, and the inductor current to know what the IC is doing.  After all these experiments and soldering, I would suggest replacing the IC since it may be damaged.  I would also confirm the components values you have on the board.  Measure your ceramic caps and resistors before you install them to make sure they are what you think they are.
    Report Abuse
    • Reply
  • Victor Titov
    on May 15 2012 18:22 PM
    Prodigy110 points
    Sorry again. Profanity removed.
    I have captured some of the waveforms, and uploaded those ready to the album. I will make more later, but it's going to be a lot of pictures. I will probably have to organize them somehow. I also have to note that from now on I am not running the converter alone. I have assembled a part of my circuit and in its current state it should be drawing 2.5 mA (on waveforms, I call it "light load", while "heavy load" is when a 68-ohm resistor is connected to Vout).
    I also have done some experimentation on heating, and now I am convinced that it is the IC's temperature that matters, not ceramic capacitors' or something else's.
    By the way, I am waiting for new chip to be delivered. I am going to replace it, along with ceramic capacitors. I hope it will help.
     Thank you!
    Report Abuse
    • Reply
  • Victor Titov
    on Jul 20 2012 12:12 PM
    Prodigy110 points
    Hello, again.
    The new board with slightly different layout. New parts. New chip from a different source. Each pin soldered with one touch of the iron.... Soft-starting Vin to prevent large surge through built-in diode... Same results. Unfortunately.
    Report Abuse
    • Reply
  • Chris Glaser
    on Jul 20 2012 12:23 PM
    Guru59335 points
    I'm sorry that you're still having issues.  Do you have part numbers for the caps you used?
    Report Abuse
    • Reply
  • Victor Titov
    on Jul 21 2012 07:00 AM
    Prodigy110 points
    No, I don't know the part numbers. For ceramic caps, I know they are Samsung, 10 uF 16 V  X5R (measured capacitance turned out to be 8.7 uF). Most probably the part number is CL21A106KOFNNN. Input side tantalum cap (now 100 uF 6.3 V) was bought looong time ago, I can't find the part number. The output side tantalum (330 uF 6.3 V) was desoldered from a dead notebook motherboard.
    Thank you very much for the help.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
