• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » LM3481 Vcc range
Share
Non-Isolated DC/DC
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
LM3481 Vcc range
LM3481 Vcc range
This question is answered
Brian Taylor1
Posted by Brian Taylor1
on May 30 2012 03:23 AM
Prodigy20 points
I wish to use the shutdown facility on this device and wish to use the potential from the Vcc pin as the bias voltage but the data sheet does not specify a value for this potential, from the description I believe this to be around 6V, can you specify range and permited loading?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • David Shenker
    Posted by David Shenker
    on Aug 06 2012 02:28 AM
    Intellectual270 points
    I would also like to know this, can some one at TI support please answer.
    Thank you
    Report Abuse
    • Reply
  • Avi Chami1
    Posted by Avi Chami1
    on Aug 06 2012 05:58 AM
    Mastermind7385 points
    According the datasheet:
    VSD - Shutdown signal threshold on FA/SYNC/SD pin:
    Output = High (Shutdown) 1.31  typ
    Output = Low (Enable) 0.68 typ
    Report Abuse
    • Reply
  • David Shenker
    on Aug 06 2012 06:09 AM
    thanks for your response Albert, but Vcc is on pin 9 and is the LDO output, and not FA.
    Report Abuse
    • Reply
  • Avi Chami1
    on Aug 06 2012 06:19 AM
    Well, the original question was to use Vcc as bias for shutdown. Thinking of it, I think it could not work because Vcc would also eventually dissapear (would it?) because of shutdown, and the output would oscillate.
    I understand that what you want to know is the value of Vcc itself?
    Report Abuse
    • Reply
  • David Shenker
    on Aug 06 2012 06:23 AM
    thanks Albert, you are correct, I am after the Vcc data only
    Report Abuse
    • Reply
  • Brian Taylor1
    on Aug 07 2012 03:27 AM
    Prodigy20 points
    Albert do you believe that Vcc is removed when the device is in shutdown? From the Functional block diagram Vin > 6V then Bias voltages are generated one of which is Vcc.
    I wish to use Vcc to bias an optoisolator so that i can have an isolated stop / start control of the regulator.
    Report Abuse
    • Reply
  • Hans-Juergen Ruhsam
    Posted by Hans-Juergen Ruhsam
    on Aug 07 2012 06:09 AM
    Expert5645 points
    Hi Brian
    As you can see in the data sheet (http://www.ti.com/product/lm3481 ) starting at page 2 pin descriptions in shut down mode the LM3481 only draw 5µA.
    On page 3 “absolute maximum Ratings” the FA/SYNC/SD pin is rated between -0.4V and 6V, which is the same as the VCC.
    Page 4 from the “electrical characteristics” the threshold is given for high and low under VSD which is typical for high (shutdown) 1.31V to a max off 1.4V and for low (enable) 0.4V to 0.68V, including NOTE 5 at page 5.
    Same information is also at page 11 of the data sheet including figure 9 and figure 10.
    Vcc is off in the shutdown mode as all other outputs.
    Best regards
    Hans
    Report Abuse
    • Reply
  • David Shenker
    on Aug 07 2012 06:23 AM
    Hi Hans would you know what the maximum load current one can draw from the Vcc (pin 9)?
    Thanks.
    Report Abuse
    • Reply
    on Aug 07 2012 07:24 AM
    Verified Answer
    Verified by Hans-Juergen Ruhsam
    Expert5645 points
    David
    there is no information available about the maximum output current for VCC, but you can go to the online product folder from the LM3481 and then use WEBENCH for a design.
    Best regards
    Hans
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
