• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » TPS62112 - voltage applied at the output
Share
Non-Isolated DC/DC
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Tom Pycke
Posted by Tom Pycke
on Jul 14 2012 03:56 AM
Prodigy60 points
I would like to use the TPS62112 in my new design. The user is offered 2 options to power the module:
 - Using 12V which is converted to 5V using the TPS62112
 - Using 5V directly on another input
How will the TPS6211 react when 5V is supplied directly to it's output pin (or the inductor), and the input is not used?
Thanks!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Paul Breakfield
    Posted by Paul Breakfield
    on Jul 15 2012 01:05 AM
    Prodigy80 points
    I don't know the answer to your question directly, but am I correct in assuming that you are asking because you want to give the user a way to power your widget directly, and that would expose the output pins to the 5v being supplied from another source?
    If so, I would,suggest incorporating a diode or simple method to limit current flow in the circuit so that it would block current going into the output pins of the TPS62112. That would ensure that there was no damage to the TPS IC and also,that the TPS IC wouldn't add any unexpected effects to your power supply or to,the circuit it is supplying.
    PTBIV
    Programming
    Entercom Communications
    Greenville, SC
    Report Abuse
    • Reply
  • Chris Glaser
    Posted by Chris Glaser
    on Jul 16 2012 08:10 AM
    Verified Answer
    Verified by Chris Glaser
    Guru59025 points
    Instead of the older TPS62112, how about the new TPS62143 (or TPS62163 if you only need 1A) family?
    All of these device and the TPS6211x are ok with having a voltage applied at the output.  Note that this voltage will appear at the input to the IC due to the high side MOSFET's body diode.  So, if you have other circuits running on the 12V bus, these will be powered from the output, through the input.
    Report Abuse
    • Reply
  • Tom Pycke
    Posted by Tom Pycke
    on Jul 23 2012 07:47 AM
    Prodigy60 points
    Hi Chris,
    Thanks for your feedback. For now I prefer to use the TPS62112... are there advantages to use the newer ones?
    I understand that putting 5V on the output will work fine, and in this situation the 5V will also appear on the input.
    One last question: what happens when there is 5V on the input (USB connected) AND there is also a battery connected (12V on the input)? I would think putting a resistor in series (with the 5V USB input) to limit the current flow would be sufficient?
    Thank you for your feedback! Much appreciated.
    Report Abuse
    • Reply
  • Chris Glaser
    on Jul 23 2012 10:53 AM
    Guru59025 points
    The newer parts support much smaller solution size, higher efficiency, better transient response, etc.
    If there is 12V on the input and 5V in the output, then the body diode will not conduct.  No current will flow, if the IC is disabled.
    Report Abuse
    • Reply
  • Tom Pycke
    Posted by Tom Pycke
    on Jul 23 2012 13:08 PM
    Prodigy60 points
    Now I see, the inductor is a lot smaller because of the higher switching frequency! That is indeed useful.
    None of the recommanded inductors for the TPS62141 is available from digikey....
    (1) s any shielded 2A inductor with 2.2uH inductance good enough?
    (2) Can I use the inductors specified in the TPS62141 (1A) datasheet for the TPS62143 (2A), assuming my design won't use more than 1.5A?
    You mention "If there is 12V on the input and 5V in the output, then the body diode will not conduct.  No current will flow, if the IC is disabled". Why do you add "if the IC is disabled?".
    (3) How can I disable the IC in such situations?
    (4)What if the IC is not disabled?
    Thanks!
    Report Abuse
    • Reply
  • Chris Glaser
    on Jul 23 2012 13:15 PM
    Guru59025 points
    Yes, any 2.2 or 3.3 uH inductor that meets the saturation current needs will work.
    You can disable the IC by pulling the EN pin to ground.  If the IC is left enabled, then it might switch to increase the 5V output to its setpoint.
    Report Abuse
    • Reply
  • Tom Pycke
    Posted by Tom Pycke
    on Aug 07 2012 15:50 PM
    Prodigy60 points
    The reason I could not find the inductors at Digikey is because there is a typo in the datasheet:
    IHPL1212BZ-11 should be IHLP1212BZ-11
    Please pass this on to the responsible to fix it.
    Just one question: the datasheet (http://www.vishay.com/docs/34289/lp12bz11.pdf) says the frequency range is 1MHz, but switching frequency is 2MHz? Isn't this a problem?
    Report Abuse
    • Reply
  • Chris Glaser
    on Aug 07 2012 15:56 PM
    Guru59025 points
    There is a submit documentation feedback link at the bottom of the datasheet pages.  Please use this to report such errors.
    The inductor worked fine in our testing.  Vishay should be contacted as to this note in their datasheets.  Better efficiency might be achieved with a coilcraft inductor.
    Report Abuse
    • Reply
  • Tom Pycke
    Posted by Tom Pycke
    on Aug 28 2012 16:14 PM
    Prodigy60 points
    Would the attached example be OK if I wanted to mix USB 5V (optionally plugged in) and the TPS62143? I am reffering to the diode in particular.
    Use cases the solution should be able to handle:
    • Only battery connected: OK!
    • Only USB connected: OK (ignoring voltage drop over diode)
    • USB and battery connected: ???
    Thank for your time,
    Tom
    Report Abuse
    • Reply
  • Chris Glaser
    on Aug 29 2012 09:16 AM
    Guru59025 points
    You can test it out on the EVM to make sure, but it should work fine.  For both sources plugged in, the diode will be off due to its high forward voltage.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
