• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Non-Isolated DC/DC » Non-Isolated DC/DC Forum » TPS54260
Share
Non-Isolated DC/DC
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
TPS54260
TPS54260
This question is not answered
eli
Posted by eli
on Aug 08 2012 09:53 AM
Genius3765 points
7462.SCHEMATIC1 _ [18]POWER DC TO DC.pdfIn
attached schematics you can see how we had implemented two step down power supplies using TPS54260DGQ.
These supplies provide 4.2VDC and 5.0VDC.
The problem we have is  as follows:
When the input voltage (NET 12V_PS_IN) goes below 8.1VDC, the power supplies stop working properly.
You can assume that pin#3 (EN) of each is above 1.5VDC
Please let me know if there is a solution, that will allow generation of the 5VCC supply and the 4V2 supply,
When the input (NET 12V_PS_IN) goes below 8.1VDC, as much as possible.
We need to operate this circuit with voltages as low as 6.0VDC
TPS54260
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Anthony Fagnani
    Posted by Anthony Fagnani
    on Aug 08 2012 10:07 AM
    Genius12265 points
    Hi Eli,
    Does the operation look similar to what is shown in Figure 3 of the following app note? http://www.ti.com/lit/an/slva444/slva444.pdf
    This shows a sawtooth shape waveform with an amplitude of ~2.1V on the output.
    If so this is due to the BOOT UVLO being tripped at light loads. Let me know and I can share you some solutions in addition to the one presented in the app note I linked above.
    Anthony
    DC/DC Power Applications Engineer
    TPS54260
    Report Abuse
    • Reply
  • eli
    Posted by eli
    on Aug 14 2012 06:59 AM
    Genius3765 points
    Hi Anthony,
    It could be a UVLO issue.Can you please send me your swolutions?
    TPS54260
    Report Abuse
    • Reply
  • Anthony Fagnani
    on Aug 14 2012 09:55 AM
    Genius12265 points
    Eli,
    Assuming it is due to the boot UVLO following is a description of what is happening. In the non synchronous buck the bootstrap capacitor is charged only when the SW node transitions to ground. When there is a load on the output the inductor current turns on the diode when the high side switch turns on pulling SW to ground. If you have no load on the output the diode doesn't conduct, the SW does not get pulled to ground and the bootstrap capacitor is not charged. If there isn't enough load the diode does not conduct long enough, the bootstrap capacitor is not charged enough each cycle and will eventually trigger the BOOT UVLO.
    The application note I linked previously presents a solution to this. Another would be to add a dummy load on the output to ensure the low side diode conducts long enough to charge the bootstrap capacitor. The size of the dummy load would need to be selected empirically. If you look at Figure 26 in the datasheet it gives somewhat of an idea the load needed.
    Anthony
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
