Will the VCC linear remain active during disable with proper VIN applied?
It is not clear in the specifications that VCC will remain active during device disable.VCC is a linear derived from VIN.The spec only states it draws less than 10uA from VIN when disabled.
Ed WalkerTexas Instruments ACAT/DCAT Support
Hi
VCC regulator is enabled by pulling up EN. In other word, VCC regulator will be disabled by pulling down EN even if a proper VIN pin voltage is applied.
LM5118 consumes about 10uA when VCC is disabled.
Regards,Eric
