I am using TPS40210 to control a flyback converter but it seems the closed-loop system is pretty close to instability. When performing a spice simulation, I found the connection between the output of the error amplifier and PWM logic is not given for TPS40210.
In a traditional chip such as 384X, there are two diodes in series, a 3 to 1 step down voltage divider, and a zener diode between its error amplifier and comparator.
So the question is, is there any "processing stage" of the current reference generated by the amplifier? If so, could you please provide the information?
Thank you.
