Hello, we recently switched form the TPS54040 because we have switched out power brick from 30V to 36V and want the headroom to go to 48V if necessary.
I have 6 boards fail shorted with the TPS54360 at 36 volts which takes out everything down stream. Schematic attached.
They seem to be fine at 30V but not at 36V. The enable is open which I thought would be ok based on the datasheet.
Desperate for a solution.
