In trying to accurately calculate a worst-case range of UVLO thresholds for a given resistor divider pair, the UVLO current source needs to be taken into account. However, I only see a typical 5uA value specified at a UVLO pin voltage of zero. If additional information is available:
1) Is there any sort of expected tolerance on that 5uA value over temperature?
2) Since the 5uA value is specified for a UVLO pin voltage of zero, does that current go down as the UVLO pin voltage rises? If so, at what rate would it approximately go down?
