Hi Team,
could you please explain the Forced Continuous Current (FCC) mode the TPS65266 uses at light loads? What happens under which conditions?
Thanks and regards,
Chris
Hi Team,
Thanks and regards,
Chris
All that means is that the internal FETs can sink current when the load current falls below ILp-p / 2. This is possible because the TPS65266 is a synchronous converter with both low and high side FETs. For a non synchronous converter with a low side catch diode, the diode can only pass current in one direction, so the converter will enter DCM when the load current falls below ILp-p / 2. Some synchronous converters use this threshold to force pulse skipping to increase light load efficiceny. TPS65266 does not have this feature.
