I would like to know if you have any element where attach the Expander TPS61202 voltage in order to weld cables with more clearance space in their connections.
Hello Mr. Charles,
First of all sorry for the delay (I was traveling).
I am a student and I am doing a work to run a small car with a hydrogen fuel cell with a power output of 0.6 volts.
I need to increase this output to 5.0 volts. For this reason, we found your “tps61202” component that gives this possibility, but the problem is that I have to connect one cable to each output (total 10) and I find almost impossible to connect securely (in 3mm I have to weld 5 cables).
Is there any adapter or electronic board to perform this operation with more space?
Thanks for your reply.
