Hi Team,
There is difference of thermal resistance value between old datasheet and revised.
Could you tell me the background of the difference?
(SLVSAX2 –SEPTEMBER 2011)
(SLVSAX2A –SEPTEMBER 2011–REVISED JULY 2015)
Yaita / Japan disty
Hi Team,
Yaita / Japan disty
All the TI datasheet has been revised to the new format. So please refer to the new datasheet and neglect the old one.
BR, Helen
Hi Helen-san,
Thank you for your reply.
I would like to ask one more.
There is a large difference of thermal resistance value between TPS61170-Q1 and the following TPS61170(non automotive) although the package is the same.
Are theses values correct?
If the answer is yes, I would also like to know the reason of the difference.
Yaita
Yaita_San,
TPS61170-Q1 and TPS61170 are different part, if they have different lead-frame, then their RϴJA will deifferent.
BR,Helen
Hi Helen-san,
I understood TPS61170-Q1 and TPS61170 are different part.
I would like to confirm if the thermal resistance of TPS61170-Q1 is the correct value just in case.
Is it correct value?
Yaita
Yaitan-San,
In generally, the data should be correct. TPS61170-Q1 is belong to the MSA team.You can contact with the engineer in that product line for detailed information.
BR,Helen
