Just received an email containing a link to your Type C power bank reference design. I see it uses this boost converter. No-where in the design doc or part spec do I see information related to input current from the battery over the possible range of the battery voltage while full load is applied.
With other competitive parts I see battery currents become excessive to the point the embedded overcurrent protection of the battery can kick in. In addition the part gets damn hot. This part has lower on resistance fets though so perhaps thermal is not so much a problem - what do you think - is a heatsink recommended? Please provide detailed battery specifications for the reference design and some more data graphs. Typical battery specs are really lacking in information so we need to know what to ask for for this circuit to work reliably and safely. While doing this you might consider what typical demands are for a power bank product - what products will be charged at 3A by such a power bank and how long must the battery be able to provide the charge?
