I am going to be using this supply to power a microprocessor board of some complexity. The output of the supply will be subjected to a large inrush current at power up due to all of the decoupling and reservoir capacitance on the board. I have read through the data sheet several times but I have not found a clear answer as to how the part will react to it. Will it go into constant-current mode and allow the output voltage to drop until the overcurrent requirement is met or will it go into a hiccup mode and never reach a regulated voltage output?
Thanks!
