TPS65252 USB and Buck2 Enable
Other Parts Discussed in Thread: TPS65252, TPS65283
Hi team,
We are working with the TPS65252 and we have a few questions:
  • Currently we are seeing 0.4V at pin LX2 when connecting pin EN2 to ground. What could be the reason for seeing this?
    • Should we expect to see 0V at LX2 if EN2 is connected to ground?
  • If we are not using the USB pins, do we just set USB_EN to low?
    • What should we connect pins rUSB, USB_VIN, USB_nILIM, USB_VO to? (high, low, floating)
Thank you,
Akash Patel
