As illustrated, the input voltage is 24V, output voltage is 3V3.
When I used the probe closed to pin SW, I found the EMI is very large.
Loot at my PCB layout.
Pls check my sch and pcb layout.
Thanks very much!
zhipan
Thanks very much!
zhipan
The layout is not too bad. I would reduce the width of the SW node a little and try to get the inductor closer to the device.
Also, I would rotate the output capacitor to shorten its ground lead.
I would strive to get the layout close to that shown in the data sheet.
