After studying all the Application Report SLVA301 - Loop Stability Analysis of Voltage Mode Buck Regulator With Different Output Capacitor Types – Continuous and Discontinuous Mode, I create a script in Matlab with all the steps described in the Design Example.
Despites all the component values calculated be exactly equal those showed in Aplication Report, the bode plots of the compensator does not are equal to that showed in Figure 15.
Below is the image copied from SLVA301 application report and the bode generated by my code in Matlab.
The filter transfer function are equal, but the error amp or compensator does not.
Someone else that already studied this application report could help me with this? Why the compesator bode plot does not are like the SLVA301 application report? I'm inserting the matlab file used to calculate.
Thank very much.
