Hi, team,
My customer met one issue about TPS54910 PG signal.
In customer's design, PG is pulled up to BIAS with 4.7k resistor. They found when TPS54910 is shutdown, PG voltage will be like below.
We tested some waveform to root the cause, and VIN, BIAS, EN, SW is normal without any issue.
Could you help verify it on EVM and give me the test result?
Thanks.
Johnny
