I need a negative converter design used to function as a preregulator for an negative regulator/LDO in a power supply design.
I am using a LLC converter/transformer with center-tapped secondary to step the voltage down to +/- 24V.
The power supply has Plus/minus outputs.
The positive voltage side is easy.
However for the negative side:
I can simulation a typical buck converter in a feedback loop around the LDO using ground/center tap acting as a floating voltage sense with the negative supply (-24V)
acting as ground. So I am converting to a lower voltage (-3V to -24V) relative to ground.
I know this is very sensitive to the negative power rail @ -24V.
Can someone suggest a better solution?
