I have been unable to get proper regulation from this flybuck design from web-bench. I've tried numerous custom solutions, and every time it is the same thing, horrible regulation over load, 24volt out drops to 20volts even with just .5amp load. Running out of ideas of what it could be, my transformer is 32uH and using a turns ratio of 2.5, therefore my primary Vout is 9.6 to 9.65volts. The Ton period looks okay at roughly 40%. Is it reasonable to think I can get proper operation from a flybuck at 24Vout and 1Amp(24watts). Is 24volts to high for an isolated voltage of a flybuck design?webench_design_LM5160 24V-1AMP.pdf
