I have a TPS40422+CSD87350 two phase design, the target loading is 60A. Attached is the schematic.
when power up with 40A loading, the board works fine, but failed to work with 60A loading.
I tried a lot check with component, soldering issue, but no improve. then I found after I heat the board to a level like above 40 degree Celsius. the board works.
So, what is the root cause for the board fail? and why the pre-heat can make it work? is there any issue with my schematic design?Power Sch.pdf
