From TPS65023 datasheet, we only get the minimum normal output capacitor value for every DC and LDO, what are their maximum values?
In work. Are there specific input and output values you are considering?
No specific input and output value,we can consider the whole input and output vlaues.
Jerel,
There is no upper limit on the input capacitors.
Any deviation from typical capacitor values on the output will have to be evaluated in terms of frequency response. The DCDC converters and LDOs are internally compensated for the capacitance in the datasheet. You could increase the capacitance by a factor of 2 but must check stability with a bode plot or load transients.
