• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » PMU » PMU Forum » TPS65023 VDC3 output voltage changing
Share
PMU
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Clay Shoup
Posted by Clay Shoup
on Apr 24 2012 16:50 PM
Intellectual410 points
We are using a TPS65023 PMIC chip to power an AM3505AZCN processor. On some of the boards (3 of the 4 tested), the 1.8V_VDC3 (DDR Power) rail is acting strangely. At powerup, it goes to 1.8V, as expected. However, on some boards, it will switch to about 2.5V after about 400 msec, and stay there.
If we do a hot reset, it will switch back to 1.8V and stay there.
We thought that it was the software changing the voltage, but we disconnected the I2C interface and the results were the same.
If you hold the reset switch, while powering up the unit, it stays at 1.8V. You only need to hold it for > 400 msec.
We used the same PMIC and processor on another design and did not see this problem.
One problem that you might notice is that the inductors are connected wrong. The boards were modified to correct this, but i'm wondering if something is shorted on the boards that are not working. However, i can't think what might cause this strange behavior.
Any help would be greatly appreciated!
TPS65023 PMIC AM35xx analog ground
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Daniel Acevedo
    Posted by Daniel Acevedo
    on Apr 24 2012 21:09 PM
    Verified Answer
    Verified by Daniel Acevedo
    Genius17070 points
    Are you able to disconnect the rail from the processor and check to see that the rail does/does not exhibit the issue? If disconnecting corrects the issue, it could be that one of the higher voltage rails is pulling this one up through the processor. You may need to look at the processor errata for a workaround such as a 10k resistor from the 1.8V rail to ground.
    Have you verified that the converter is stable by looking at the output voltage with an oscilloscope?
    You mention that the inductors were initially connected wrong and corrected; this might be an issue since switch mode power supplies are sensitive to layout. Can you please provide schematic and layout and please note the fix?
    Report Abuse
    • Reply
  • Doug Goss1
    Posted by Doug Goss1
    on Apr 25 2012 11:06 AM
    Verified Answer
    Prodigy30 points
    It turns out that the cap on the PWRFAIL SNS was too large. A 1uF was used, for some reason, instead of the 1000pF suggested in the TI docs.
    It held off the 3.3V from turning on for about 400 msec. Not sure why this would cause the problem, but i changed it to 1000 pF and the output is now 1.8V.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
