• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » PMU » PMU Forum » TWL6030 just shuts down after power up
Share
PMU
  • Forums
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Ole Steinhauer
Posted by Ole Steinhauer
on Aug 01 2012 04:41 AM
Prodigy105 points
I'm working on a project including the OMAP4460 and TWL6030. Very similar to "Pandaboard". Now I experience the following:
I supply power (3,7V) to VBATT, I see all voltages ramping up on my scope. Just when the last voltage is fully ramped up, I see the power off sequence. NRESPWRON is never set by TWL. VIO1,8 is up for just 15,5ms. I see all voltages going down like shown in the datasheet. All voltages seem to reach full level, so I guess there is no short circuit.
Maybe I'm getting something wrong, but should the power on state last at least until the watchdog timer disables the device? Even if the OMAP is not responding? Since NRESPWRON is never released to HI level the OMAP will not start to boot.
Would a "short circuit" on a single rail result in a shut down? Or will it disable just a single rail.
I see VRTC present all the time. Also the 32khz clock is running. When I manually set the "PWRON" the whole sequence happens again. Power ramps up, power shuts down.
Thanks for any help on this!
Ole.
NRESPWRON TWL6030 OMAP SEQUENCE
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • hariseran kannan
    Posted by hariseran kannan
    on Aug 04 2012 06:50 AM
    Prodigy50 points
    Hi Ole,
    We are also facing the same issue in our board. We are using TWL6030B1AACMR in our board.
    Please let us know the complete part no. of the PMIC and have you have resolved it
    Hariseran
    Report Abuse
    • Reply
  • Hans Little
    Posted by Hans Little
    on Aug 05 2012 11:58 AM
    Prodigy10 points
    Hi Hariseran, hi Ole,
    we are having exactly the same problem with our board! The PMIC we are using is  TWL6030B107CMR and the processor is OMAP4430 ES 2.2
    I will be really appreciated, if you have solve  this problem!
    Hans
    PMIC Omap 6030 TWL
    Report Abuse
    • Reply
  • hariseran kannan
    on Aug 06 2012 01:15 AM
    Prodigy50 points
    Hi Ole, Hans,
    Yes we have resolved the issue. In our PMIC TWL6030B1AACMR primary watchdog timer was there. Watchdog timer expects all the PMIC outputs has to be available. We were not using VCORE3 SMPS and VMEM SMPS and connected the respective Feedback voltage to ground. So we connected some voltage to that feedback and it started working.
    Hariseran
    Report Abuse
    • Reply
  • Aneeshkumar V R
    Posted by Aneeshkumar V R
    on Aug 08 2012 12:17 PM
    Prodigy105 points
    Hi Ole ,
      Could you please tell me do you have any solution for this issue , you got yet ?
    I am facing issue almost similar , But I couldn't get 1.8V ramp up too .
    Aneesh
    Report Abuse
    • Reply
  • Aneeshkumar V R
    on Aug 08 2012 12:24 PM
    Prodigy105 points
    Hariseran,
         your point is correct I guess you also following the ref design as panda.  they did same as Vcore3 and vmem are not used and Fb for those connected to GND .
    and Datasheet of PMIC (TWL6030) also suggested same , if unused connect Fb pin to GND . So I guess may be some option to discard this situation instead of giving voltage to this balls ?
    in my case I can't do this since I din't taken out this balls .. connected to GND in top layer itself under the BGA . :(
    Report Abuse
    • Reply
  • Ole Steinhauer
    on Aug 08 2012 13:25 PM
    Prodigy105 points
    Hi Aneeshkumar,
    I wanted to try the modification Hariseran suggested. But It's the same here. I connected the FB balls to gnd, this connection is under the BGA now. I'm waiting for replacement chips which have the watchdog disabled. But I'm not sure that this is the solution.
    I also contacted our TI FAE on this topic, he is checking this right now.
    Sadly also the TESTEN pin is also inaccessible in my design, this pin can also disable the primary watchdog.
    I hope the FAE will come up with a solution, If I have a solution I will post immediately.
    Right now I have supplied my board voltages externally via a bench supply. So my board is working fine. But the PMIC still makes me grey hair.
    Ole.
    P.S. I checked my supplier and my Chips should be P/N TWL6030B107CMR.
    Report Abuse
    • Reply
  • Aneeshkumar V R
    on Aug 09 2012 08:47 AM
    Prodigy105 points
     Hello Ole ,
    I was facing some BGA Soldering issue , once i solved that  now I am also in same stage as you face ,and I have the same part TWL6030B107CMR .
    But as per the TWL6030 datasheet , this part is Primary watchdog disabled . how you concluded this is watch dog  reset any particular observation for this ?
    Aneesh
    Report Abuse
    • Reply
  • Ole Steinhauer
    on Aug 09 2012 09:00 AM
    Prodigy105 points
    I was just guessing the watchdog is the problem. The "on time" of my PMIC is very reproducible every time I power cycle the board. This does not look like a "analog" problem to me. Even VRTC and 32k osc seem to work fine. Waking up the PMIC via "PWRON" pin works, but just for some milliseconds.
    Hope TI FAE will come up with some solution or idea.
    Regards, Ole.
    Report Abuse
    • Reply
  • Suhas M
    Posted by Suhas M
    on Aug 10 2012 05:48 AM
    Prodigy65 points
    Hi Ole and Aneesh,
    I and Hariseran work in same project. As per my observation there is short circuit protection inside PMIC which will trigger the primary watchdog to shut off the PMIC with in 10 ms(except for VRTC). I could see only feedback on each SMPS as sense line to detect short circuit and in our design we have grounded these FB lines (VMEM and VCORE3). I know this is contradicting, as datasheet recommends to ground the FB lines but other than this I don't see any explanation. We also used PMIC without watchdog in previous design and there was no problem even though feedback is grounded.
    Suhas M
    Report Abuse
    • Reply
  • Ole Steinhauer
    on Aug 10 2012 06:02 AM
    Prodigy105 points
    Hi Suhas,
    So I see my options are: New PCB with unused FB pins not connected GND, or a TWL6030 replacement with watchdog disabled. Do you have a list of available EPROM options / part numbers? I think the EPROM is not user programmable.
    Regards, Ole.
    Report Abuse
    • Reply
  • Aneeshkumar V R
    on Aug 10 2012 06:59 AM
    Prodigy105 points
    Hi Ole , please see the list of parts
    Report Abuse
    • Reply
  • Ole Steinhauer
    on Aug 11 2012 04:07 AM
    Prodigy105 points
    Thanks for the list, I recently ordered TWL6030B107CMR as samples. Today I replaced my TWL with one of the samples. The problem still exists.
    So sadly no news here.
    Ole.
    Report Abuse
    • Reply
  • hariseran kannan
    on Aug 11 2012 06:29 AM
    Prodigy50 points
    Hi Ole,
    Have you referred the schematics of Panda board with omap4460 or omap4430. There are some differences in the power connection of core1,2,3 for both these OMAP devices with the PMIC TWL6030.
    Suhas told that the TWL6030B107CMR cannot be used for OMAP4430 as mentioned in the above table.
    Hariseran
    Report Abuse
    • Reply
  • Aneeshkumar V R
    on Aug 11 2012 07:03 AM
    Verified Answer
    Verified by Ole Steinhauer
    Prodigy105 points
    Hi Ole ,
         I was using the part  "TWL6030B107CMR" by default , there we faced the issue .  Now we changed the part with  "TWL6030B1A4CMR" . PMIC is working properly with this Chip now .
    I have analyzed the few things , and concluded that VMEM  , Power supply FB connected to GND should be the cause .  Observations to justify this are ,
    i) in Panda Rev A  they have the  TWL6030B107CMR part and they using the VMEM power , Board is working with out issue .
    ii)  In panda ES , VMEM not used , FB is connected to GND . But they using the part " TWL6030B1A4CMR" .
    iii) In Boot mode configuration for the PMIC ,
             TWL6030B107CMR   - VMEM will not disable only the voltage levels will change 1.2V or 1.35 V depends on the "Boot 1" pin state "low " or "high ".
             TWL6030B1A4CMR  - VMEM  VMEM is not controlled by start-up sequence.
    iv) If we select the Mode 1  as "high"  . the same behavior we could produce on Panda ES Board .
    I have tried all these from those I conclude VMEM Power , either we have to disable at power up (this option avilable only in TWL6030B1A4CMR or higher series .) else we have to use this power supply ( I mean should not connect the FB pin to GND as given in datasheet ).
    Aneesh
    Report Abuse
    • Reply
  • Ole Steinhauer
    on Aug 11 2012 09:20 AM
    Prodigy105 points
    Hi Aneesh,
    Thank you for your detailed reply. I just ordered some TWL6030B1A4CMR from ti. I will post my results as soon as I get the devices.
    Thanks!
    Best Regards, Ole.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
