We have a momentary switch that we intended to use as a reset button - it pulls PB_IN' to the system voltage (SYS) when pressed. Otherwise, there's a 100k pulldown to GND.
The switch works fine, but the device is not reset. Am I misunderstanding the function of PB_IN'?
If I want to power cycle the device, should I use HOLD_DCDC1 and HOLD_LDO1 instead?
Thanks very much!
