The TPS659037 requires an external oscillator to operate. I have read in several E2E posts that it must have a crystal oscillator (sine wave). My customer is asking the following question:
This is the oscillator that I want to use with the TPS659037:
SG-210STF
http://www5.epsondevice.com/en/products/spxo_standard/sg210stf.html
This is CMOS output oscillator. I'm trying to understand if we can use crystal oscillator (Crystal unit + oscillation circuit) instead of just the crystal unit.
Can you verify if this oscillator would work and if so send a diagram of how the customer should configure it to work properly with the TPS659037? I do not believe that it will work from the comments in the forum, but I need you to verify this for the customer.
Thanks for your help with this!
Richard Elmquist
