Other Parts Discussed in Thread: TPS65912, TPS65911
On one of our boards we are using TPS65910AA1RSLR PMIC to charge the rechargeable LI-Ion battery. Lithium ion battery is used for RTC as backup power. While going through UL approval for the board, looks like the TI part TPS65910AA1RSLR is not UL evaluated under QVGS, file E169910 (Protectors, Low-voltage Solid-state Overcurrent - Component)
Do you know if this part is under UL evaluation process or any plans of getting it UL evaluated soon?
Do you have any recommendation for alternate TI pin compatible part ( UL evaluated) which can be used, since the design is done and it is too late to redesign/respin the board?
Thank you!
