Other Parts Discussed in Thread: AM3354,
my customer is using TPS65217C to power AM3354 and has some issue.
They power TPS65217C with regulated 5V applied to AC pin, BAT pin unconnected.
They monitored the 5V input and it's good, no dip. And they can see that the current sourced from 5V is less then 100mA.
But the voltage on SYS pin drop periodically, the waveform is as below, the voltage of SYS will work for 5-6 seconds and then drop for 1 second.
The temperature should not be a problem because no apparent heat up.
Could you please give some suggestions on how to fix the problem? Thanks.
