Hello guys,
One of our customers is considering using TPS65916 for Renesas processor, R8A77450.
I attached a R8A77450 information.
Also you can see other information on the following URL.
1. RZ/G1E Module with Renesas R8A77450
https://elinux.org/RZ-G/Boards/SK-RZG1E
2. Renesas RZ/G1M Starter Kit board
www.emtrion.de/.../emcon-rz-g1e-65.html
This board uses Dialog Semiconductor, DA9603
DA9603 datasheet
www.dialog-semiconductor.com/.../da9063_datasheet_2v1.pdf
Our customer asked us several questions as the follows.
(1) Can R8A77450 be used for R877450? Or has TI supported the processor by TPS65916?
(2) If the answer for (1) is yes, does TI have any document about TPS65916 schematic and BOM?
(3) OTP data in TPS65916 can be programmed by user?
(4) If the answer for (2) is yes, could you tell me how to program the OTPs?
Could you please answer the above questions.
Your answer would be much appreciated.
Kazuya Nakai.
