Dear Specialists,
My customer is considering TPS65381A-Q1 and has questions.
I woould be grateful if you could advise.
(1) Is the register value of TPS65381A - Q1 reset to the initial value each time it is activated?
(2) When an error occurred in TPS65381A-Q1, and move to STANDBY mode or RESET mode,
does the resister value at normal startup remain the same? Or it will be initialized?.
(3) By comparing the value of register to be set at startup (for example, Window of WD) with the default value,
is it possible to know whether the startup is normal startup or abnormal startup?
I appreciate your great help in advance.
Shinichi
