The datasheet for the PMIC does not mention what to do with the SCL and SDA lines if they are unused. Since the board will not have a 3.3V supply until after the PMIC is turned on, should they be tied to the 3.3V output of the PMIC or tied to ground?
Additionally, if they are tied to the 3.3V output should this be done through a pullup or straight to the rail?
Kevin
