• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » PMU » TPS659xx PMU Forum » TPS65921 BSDL file
Share
PMU
  • Forums
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
TPS65921 BSDL file
TPS65921 BSDL file
This question is answered
Jeff Mogensen
Posted by Jeff Mogensen
on Sep 06 2011 07:32 AM
Prodigy130 points
Can you post the TPS65921 BSDL file developing JTAG boundary scan tests?
I have found the TPS65920 BSDL file at TPS65920 BSDL Models  (ZIP 3 KB)  to use as a short-term work-around; however, I assume that the IO will be different per Differences in Features for TPS65920 and TPS65921 (Rev. B)  (PDF  41 KB)  (e.g.  TPS65920 has a 6x6 keypad interface vcs. TPS65921 has an 8x 8 keypad interface).
Jeff
JTAG TPS65920 PMIC TPS65921
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • James Smith
    Posted by James Smith
    on Oct 11 2011 14:25 PM
    Prodigy655 points
    Hi Team,
    Any follow up on this question?
    TPS65920 TPS65921
    Report Abuse
    • Reply
  • Jeff Mogensen
    on Oct 21 2011 15:30 PM
    Prodigy130 points
    Is there another way to get a response to this item? Does anyone have this BSDL file?
    Jeff
    Report Abuse
    • Reply
  • James Smith
    on Oct 25 2011 13:29 PM
    Prodigy655 points
    Hi Jeff,
    I have a copy of the BSDL file. We're waiting to see if there is a newer version before posting it to the forums, but it should be good for a starting point, feel free to e-mail me at smithjr2@ti.com and i'll send the copy to you.
    Report Abuse
    • Reply
  • Jeff Mogensen
    on Oct 28 2011 16:15 PM
    Verified Answer
    Verified by Jeff Mogensen
    Prodigy130 points
    TPS65921 BSDL file works. Thanks, Jeff
    Report Abuse
    • Reply
  • Karl Radestam
    Posted by Karl Radestam
    on Feb 16 2012 18:37 PM
    Prodigy20 points
    Jeff or anybody else reading this, can you forward me the bsdl for the TPS65921? Our company is finalizing board layout now. Thank you. Karl Radestam
    Report Abuse
    • Reply
  • Jeff Mogensen
    on Feb 20 2012 14:06 PM
    Prodigy130 points
    tps65921_bsdl.txt
    Karl,
    Attached is the  TPS65921 BSDL file for the  ZCH package that I received from Smith, James [smithjr2@ti.com] . However, an entry needs to be created for the  ZQZ package since that is how the part is sold. Also, the IDCODE_REGISTER most likely has changed since this file is from 06/19/2009.
    Please send me a copy of the file with the ZQZ entry if you or TI decide to update.
    Good Luck!
    Jeff
    Report Abuse
    • Reply
  • Karl Radestam
    on Feb 22 2012 11:30 AM
    Prodigy20 points
    Hi Jeff,
    Thanks for sending the file. I forwarded it to our TI rep and they discussed internally at TI and below is their response. I suspect TI is selling this part with faulty internal boundaryscan cells or registers and they tell customers they will not support the jtag in anyway, but they also acknowledge that the jtag does operate ok in TESTMODE and that the port is used in their factory for testing. I was really hoping TI could help more.
    Karl
    Sent: Tuesday, February 21, 2012 10:35 AM
    To: Radestam, Karl; Rhodes, Donald
    Cc: Duncan, Jerry; Howard, Brett
    Subject: RE: [TPS659xx PMU Forum] 65921 JTAG reference document(s)
    Importance: High
    The BSDL file you are referring to is not complete nor will it be supported by TI.  If Datalogic decides to use this file TI will not be able to support this effort.  The JTAG for this device was not intended to be for customer use.  I have requested they remove any JTAG support out of the datasheet. I have talked to the factory and the files you are inquiring about will be use at your own risk and will not be supported via. TI. Sorry for the confusion.  You may find data and files on the e2e but TI cannot support everything on the e2e.  We simply do not have the manpower to do so.
    Phil
    Report Abuse
    • Reply
  • Jeff Mogensen
    on Feb 22 2012 11:55 AM
    Prodigy130 points
    tps65921_BSDL_rev1.txt
    Karl,
    see attached to use at your own risk
    Jeff
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
