• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » PMU » TPS659xx PMU Forum » TPS65921 with AM37xx I2C1 lockup
Share
PMU
  • Forums
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Gunter Schmer
Posted by Gunter Schmer
on Apr 16 2012 11:04 AM
Expert4290 points
Hi all,
a customer is using the TPS65921 with the AM3703 and they are running into an I2C1 lockup issue when an external hosts resets (PWRONRESET) the AM3703 during an ongoing I2C1 transaction. The I2C1 from then on stays locked and cannot be used until the board is power cycled. This seems to be very similar failure mode as has been seen with the TPS65950. I was made aware of the following changes to the board.c file in order to fix this problem for the '950 in Linux.
static struct twl4030_ins wrst_seq[] __initdata = {
 * Reset twl4030.
 * Reset VDD1 regulator.
 * Reset VDD2 regulator.
 * Reset VPLL1 regulator.
 * Enable sysclk output.
 * Reenable twl4030.
                {MSG_SINGULAR(DEV_GRP_NULL, RES_RESET, RES_STATE_OFF), 2},     //added
                {MSG_SINGULAR(DEV_GRP_P1, RES_VDD1, RES_STATE_WRST), 15},
                {MSG_SINGULAR(DEV_GRP_P1, RES_VDD2, RES_STATE_WRST), 15},
                {MSG_SINGULAR(DEV_GRP_P1, RES_VPLL1, RES_STATE_WRST), 0x60},
                {MSG_SINGULAR(DEV_GRP_P1, RES_HFCLKOUT, RES_STATE_ACTIVE), 2},
                {MSG_SINGULAR(DEV_GRP_NULL, RES_RESET, RES_STATE_ACTIVE), 2},   //added
static struct twl4030_script wrst_script __initdata = {
                .script = wrst_seq,
                .size   = ARRAY_SIZE(wrst_seq),
                .flags  = TRITON_WRST_SCRIPT,
Questions:
(1) Is this the correct (complete) workaround, or are there other things to consider?
(2) Does this TPS65950 workaround also apply to the TPS65921?
(3) How does the above sequence apply for the AM37xx PWRONRST, i.e. in the customer case an external host asserts the PWRONRST on the AM37xx to cause a reset. I want to make sure that the additional PMIC initialization is part of this reset sequence.
--Gunter
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Gunter Schmer
    on Apr 16 2012 19:19 PM
    Expert4290 points
    Hi all,
    One side question: Would a simultaneous NRESWARM (to the PMIC) simultaneous to the AM37xx PWRONRST clear up the I2C lock also? The customer system allows for that with right resistor population.
    --Gunter
    Report Abuse
    • Reply
  • Gunter Schmer
    on Apr 17 2012 16:13 PM
    Expert4290 points
    Hi all,
    do you have an update on the above?
    --Gunter
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on Apr 19 2012 13:24 PM
    Prodigy90 points
    I'd like to try the
    patch you referenced:
    http://e2e.ti.com/support/power_management/pmu/f/43/t/182798.aspx
      for the I2C lockup issue.  This patch seems to be for a Nokia
      product and doesn't really apply to the Beagleboard.  I could lift
      the whole 4030 script structure and put it in the Beagleboard board
      file:
    arch/arm/mach-omap2/board-omap3beagle.c
      Do you recommend this?
      I'm not sure whether I need to use all four members in:
    static struct twl4030_script *twl4030_scripts[] __initdata = {
        /* wakeup12 script should be loaded before sleep script, otherwise a
           board might hit retention before loading of wakeup script is
           completed. This can cause boot failures depending on timing issues.
        &wakeup_script,
        &sleep_on_script,
        &wakeup_p3_script,
        &wrst_script,
      Seems like we just need &wrst_script but I'm not sure...
     Any help is greatly appreciated.
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on Apr 19 2012 13:59 PM
    Prodigy90 points
    I put the code in and it's telling me:
    [    0.158020] TWL4030: Bad order of scripts (sleep script before wakeup) Leads to bootfailure on some boards
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on Apr 19 2012 14:12 PM
    Prodigy90 points
      Looks like there may have been a fix for this:
    http://www.mail-archive.com/linux-omap@vger.kernel.org/msg45509.html
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on Apr 19 2012 14:27 PM
    Prodigy90 points
    Still getting errors with this addition:
    Starting vsftpd: OK
     Enabling hot-plug: [   11.566680] omap_i2c omap_i2c.1: Arbitration lost
    [   11.597564] omap_i2c omap_i2c.1: omap_i2c_bus_clear stat = 0x0, was 0x0 systest = 0x1e0
    [   11.606018] twl: i2c_read failed to transfer all messages
    [   12.621185] omap_i2c omap_i2c.1: timeout waiting for bus ready
    [   12.636871] omap_i2c omap_i2c.1: omap_i2c_bus_clear stat = 0x0, was 0x1000 systest = 0x1e0
    [   12.645568] twl: i2c_write failed to transfer all messages
    [   12.651306] ------------[ cut here ]------------
    [   12.656188] WARNING: at drivers/usb/otg/twl4030-usb.c:331 twl4030_i2c_access+0x58/0x110()
    [   12.664733] Modules linked in: g_ether(+)
    [   12.669006] [<c0040d1c>] (unwind_backtrace+0x0/0xec) from [<c0067bac>] (warn_slowpath_common+0x4c/0x64)
    [   12.678863] [<c0067bac>] (warn_slowpath_common+0x4c/0x64) from [<c0067bdc>] (warn_slowpath_null+0x18/0x1c)
    [   12.688964] [<c0067bdc>] (warn_slowpath_null+0x18/0x1c) from [<c02f92e8>] (twl4030_i2c_access+0x58/0x110)
    [   12.699005] [<c02f92e8>] (twl4030_i2c_access+0x58/0x110) from [<c02f93bc>] (__twl4030_phy_resume+0x1c/0x44)
    [   12.709228] [<c02f93bc>] (__twl4030_phy_resume+0x1c/0x44) from [<c02f93fc>] (twl4030_phy_resume+0x18/0x24)
    [   12.719329] [<c02f93fc>] (twl4030_phy_resume+0x18/0x24) from [<c02f9488>] (twl4030_set_suspend+0x1c/0x24)
    [   12.729370] [<c02f9488>] (twl4030_set_suspend+0x1c/0x24) from [<c032e310>] (omap2430_runtime_resume+0x3c/0x44)
    [   12.739868] [<c032e310>] (omap2430_runtime_resume+0x3c/0x44) from [<c02b59bc>] (pm_generic_runtime_resume+0x2c/0x38)
    [   12.750915] [<c02b59bc>] (pm_generic_runtime_resume+0x2c/0x38) from [<c02b7a58>] (rpm_callback+0x38/0x44)
    [   12.760925] [<c02b7a58>] (rpm_callback+0x38/0x44) from [<c02b86b0>] (rpm_resume+0x2a0/0x364)
    [   12.769775] [<c02b86b0>] (rpm_resume+0x2a0/0x364) from [<c02b8610>] (rpm_resume+0x200/0x364)
    [   12.778625] [<c02b8610>] (rpm_resume+0x200/0x364) from [<c02b898c>] (__pm_runtime_resume+0x30/0x48)
    [   12.788116] [<c02b898c>] (__pm_runtime_resume+0x30/0x48) from [<c032a0b8>] (usb_gadget_probe_driver+0x58/0x1b4)
    [   12.798706] [<c032a0b8>] (usb_gadget_probe_driver+0x58/0x1b4) from [<c00373a4>] (do_one_initcall+0x90/0x160)
    [   12.809020] [<c00373a4>] (do_one_initcall+0x90/0x160) from [<c00911e0>] (sys_init_module+0x1398/0x1538)
    [   12.818847] [<c00911e0>] (sys_init_module+0x1398/0x1538) from [<c003c700>] (ret_fast_syscall+0x0/0x30)
    [   12.828613] ---[ end trace 3f066241ed6d15fc ]---
    [   12.887817] twl: i2c_read failed to transfer all messages
    [   12.893676] twl4030_usb twl4030_usb: Timeout setting T2 HSUSB PHY DPLL clock
    Report Abuse
    • Reply
  • Philippe Perney
    Posted by Philippe Perney
    on Apr 27 2012 14:00 PM
    Prodigy420 points
    Sorry, the team is 100% hardware and I cannot go in such details.
    Root cause of the issue is when an I2C transfer is interrupted at Master side the PMIC I2C is still waiting for the rest of the transaction for a while.
    There are two solutions,
    1/ the master is abble to complete the transfer
    2/ knowning that in normal application mode the transaction is interrupted by a warm reset. Program the PMIC to reset itself when it receives a warm reset. This is the purpose of the requested sequence which is just the normal way to use the device.
    When sequence is filled in don't forget to enable the warm reset (P1_SW_EVENTS, P2_SW_EVENTS, P3_SW_EVENTS registers)
    If the I2C transfer interrupt is initated by something else it should also generate a warm reset to the PMIC.
    Philippe
    tps65921 warm-reset i2c-lock
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on May 02 2012 09:37 AM
    Prodigy90 points
    Hi Philippe,
      I've installed the patch for the script and have added a feature in the i2c driver that clocks out 16 clocks when it detects a stuck data line in the hope of freeing a stuck peripheral that is waiting for a i2c transaction and has control of the SDA line.  When I installed the "16 clock" feature, the frequency of hangs went way down so I believe it is working.  Now when I test by continually resetting the OMAP it takes about an hour for a hang.  I have brought out the SDA and SCL lines and the hang I see now is that the SCL line is stuck low.  It would seem that the PMIC is holding it low since I can take the OMAP through a complete reset, load software and it's still low.  There is a feature in the i2c peripheral to output a square wave on the SCL line but when I try this in the stuck mode, nothing happens, the line is still stuck low.
      Questions for you:
    1. Do you know about this problem?
    2. How do I know the script is working?  Is there a way I can read it out and verify that it really got loaded?
      Thanks much.
     Rick Bronson
    Report Abuse
    • Reply
  • Philippe Perney
    on May 08 2012 12:58 PM
    Prodigy420 points
    It looks surprising to me. I propose to dump the sequencer to crosscheck the code.
    SEQ_ADD_W2P
    SEQ_ADD_P2A
    SEQ_ADD_A2W
    SEQ_ADD_A2S
    SEQ_ADD_S2A12
    SEQ_ADD_S2A3
    SEQ_ADD_WARM
    Philippe
    Report Abuse
    • Reply
  • onsonck
    Posted by onsonck
    on May 08 2012 17:42 PM
    Prodigy90 points
    Hi Philippe,
      I ran this same kernel on the BeagleBoardXM and it works fine. The
    SEQ is being programmed correctly.  So it seems to have something to
    do with the different PMIC chip we are using.  Just for your info the
    IDCODE of the BBXM is:
    [    0.099517] idcode addr = 0x00 = 0x2f
    [    0.099578] idcode addr = 0x01 = 0x00
    [    0.099670] idcode addr = 0x02 = 0x09
    [    0.099731] idcode addr = 0x03 = 0x30
      Our IDCODE is:
    [    0.119171] idcode addr = 0x00 = 0x2f
    [    0.119232] idcode addr = 0x01 = 0x80
    [    0.119323] idcode addr = 0x02 = 0x77
    [    0.119384] idcode addr = 0x03 = 0x1b
      The problem seems to be the PROTECT_KEY register.  When the BBXM
    sets this register to unlock, it reads back a 0x02:
    [    0.098052] unprotect_pm_master addr = 0x0e = 0x02
      Which from the manual:
    Read 10 when access to Power Configuration Registers is
    enabled
      When we set it we read back 0x00 which means we have no access.
      Any ideas?
      Rick
    Report Abuse
    • Reply
  • Gunter Schmer
    on Jul 13 2012 17:44 PM
    Expert4290 points
    Hi all,
    was there any more resolution to the problem of unlocking the PMIC register and appropriately writing the warm reset script correctly for this PMIC?
    --Gunter
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
