For TPS65910A3, the user guide document 'SWCU093C' has the power on timings for TPS65910A3 when connected to AM3352. It shows that pwrhold ramps up just after the VRTC supply is stable.
In our case we have connected the PWRHOLD input to an open drain reset. and a pull up is provided to VMMC supply of PMIC. In this case when the board is powered on (when VMMC is not present) because of internal pull down on PWRHOLD pin this signal will remain low.
In this case will the PMIC start normally? the PWRHOLD will only go high when VMMC is present.
Thanks & Regards,
Nikhil
