• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » PMU » TPS659xx PMU Forum » [TPS65920] Backup mode current consumption @ BKBAT
Share
PMU
  • Forums
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Antony Lin
Posted by Antony Lin
on Oct 07 2010 00:42 AM
Intellectual2660 points
 We're trying to measure backup mode current consumption, and see if it's around 2.25uA as specified.  The test procedure is as below.
1. Connect 3.7V at VBAT, and 2.7V at BKBAT.
2. Remove VBAT 3.7V after booting, and only 2.7V BKBAT supplies system
3. Measue drain current  from BKBAT  ---> 2.7V/7.56uA (100ohm+/-1% resistor as current sense)
4. Re-connect 3.7V at VBAT.
5. Check if RTC keeps when VBAT is removed.
It seems the backup mode current is 7.56uA which is bigger than 2.25uA as specified.  Can you help to indicate if there's anything incorrect for our test set-up and configuration?
Antony
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Søren Steen Christensen
    Posted by Søren Steen Christensen
    on Oct 07 2010 15:33 PM
    Genius3055 points
    Hi Antony,
    Although it doesn't help much I can confirm to have seen similar results while doing a 99% similar test. One idea which might bring down the power consumption (which I unfortunately first realized later than at the time of doing my test) is to set the CK32K_LOWPWR_EN-bit in TPS65950 in order to let the 32kHz clock run in low power mode when VBAT is low.
    I however haven't tested the effect of this yet. In case you do this, could you please update this thread to let me know if this is the magic trick of bringing down the BKBAT draw from the measured 7.56uA to the specified 2.25uA?
    Best regards and thanks
      Søren
    Søren Steen Christensen - SSC Solutions ApS - Web: www.ssc-solutions.dk
    Report Abuse
    • Reply
  • Antony Lin
    on Oct 08 2010 02:35 AM
    Hi Søren,
    It drops 1.7xuA with  CK32K_LOWPWR_EN=1.  Do you think there's any side effect with this setting?
    Antony
    Report Abuse
    • Reply
  • Gandhar Dighe
    Posted by Gandhar Dighe
    on Oct 08 2010 16:16 PM
    Genius15110 points
    Thanks Soren.
    Antony,
    In backup there is no need for excess consumption. So, this setting is ok.
    Gandhar.
    Gandhar
    Kindly click the Verify Answer button on this post, if it answers your question.
    Report Abuse
    • Reply
    on Oct 09 2010 10:59 AM
    Genius3055 points
    Hi Gandhar,
    You are welcome, but apparently setting this bit doesn't solve the whole topic? As I understand the reply it saves ~1.7uA out of ~7.5uA, which still leaves the total consumption at ~5.8uA, which is around 2.5 times what to expect from the datasheet (2.25uA)? Any ideas about how to get the last step down to 2.25uA?
    Best regards and Thanks
      Søren
    Report Abuse
    • Reply
  • Antony Lin
    on Oct 13 2010 22:02 PM
    Hi Søren,
    I'm sorry that I made some misunderstanding.
    After applying the setting, the backup mode current is around 1.7uA now.
    Antony
    Report Abuse
    • Reply
    on Oct 15 2010 09:46 AM
    Genius3055 points
    Hi Antony,
    No worries. I'm just glad that this did the magic trick :-) And that it did it that much that I believed that you "x" meant times and not just a "random" number following the 7 :-) Actually what you now measure it 0.5uA (~20%) less that typical consumption according according to datasheet, which was so great that I couldn't believe it :-)
    Thanks for updating me on this - Enjoy your weekend
      Søren
    Report Abuse
    • Reply
  • Antony Lin
    on Oct 20 2010 03:07 AM
    Hi Gandhar,
    After enable the CK32K_LOWPWR_EN bit to '1', they found the RTC drift increase from 1sec/Day to 4~5sec/Day.  (VBAT is not avaiable)
    - Do you think this is reasonable?
    - The above drift is measured with compensation enabled, do you think compensation is nnot working when CK32K_LOWPWR_EN=1?
    - Is it normal there's no clock from CLK32kout when CK32K_LOWPWR_EN=1?
    - Regarding the backup mdoe current specified in DM (2.25uA), is it done with CK32K_LOWPWR_EN=1 or 0?
    Antony
    Report Abuse
    • Reply
  • Gandhar Dighe
    on Oct 20 2010 12:21 PM
    Genius15110 points
    Hi Antony,
    Setting 32K to low power is correct and needed for the correct estimation of consumption, data sheet has this setting. Clock will be active in this setting.
    I dont have data for drift, I will find out and let you know.
    Gandhar.
    Gandhar
    Report Abuse
    • Reply
    on Oct 20 2010 12:46 PM
    Genius3055 points
    Hi Gandhar,
    Are you sure CLK32kout is expected to be on when CK32K_LOWPWR_EN=1?
    AFAIR it's expected to be switched off (as found by the questioner) in order to save power, but I might remember wrong?
    Thanks for clarifying and double checking
      Søren
    Report Abuse
    • Reply
  • Gandhar Dighe
    on Oct 20 2010 13:41 PM
    Genius15110 points
    Hi Antony,
    Your reading are all correct.
    In low power mode the clock drift is normal. The 32K clk is active in this mode. When the setting is in normal mode then you will see an approximate increase of 4uA. This is what you are seeing.
    Unfortunately your customer will have to pick one of two options - power vs. accuracy..
    Gandhar.
    Gandhar
    compensation 32k 32khz 32kHz clock 32K accuracy 32 khz 32KCLK accuracy
    Report Abuse
    • Reply
    on Oct 20 2010 16:42 PM
    Genius3055 points
    Hi Gandhar,
    Sorry for being a bit slow on this tonight (EU time), but just to be 100% sure. Are you saying, that the CLK32kout-pin is expected to be on/driven even when CK32K_LOWPWR_EN=1? In this case there might be something "wrong" with Antony Lins setup since he is reporting that it's off (please see his last post on this thread) when setting the bit.
    Best regards and thanks for the continued support
      Søren
    Report Abuse
    • Reply
  • Antony Lin
    on Oct 20 2010 21:02 PM
    Hi Gandhar,
    When you said "Unfortunately your customer will have to pick one of two options - power vs. accuracy", do you mean the higher RTC drift is expected?
    Antony
    Report Abuse
    • Reply
  • Gandhar Dighe
    on Nov 11 2010 18:26 PM
    Genius15110 points
    Hi Antony,
    Yes, you are correct.
    Gandhar.
    Gandhar
    32khz accuracy drift
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
