• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Power Interface » Power Interface Forum » LM5088-1
Share
Power Interface
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
LM5088-1
LM5088-1
This question is not answered
jerry booth
Posted by jerry booth
on Jan 05 2012 10:57 AM
Prodigy60 points
Does the LM5088-1 require a minimum load?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • EricLee1880267
    Posted by EricLee1880267
    on Jan 06 2012 11:20 AM
    Expert5320 points
    At light /no load, LM5088 skips HG pulses if a required on-time is less than 'Minimum HG on-time.
    LM5088
    Report Abuse
    • Reply
  • Roger Johnson
    Posted by Roger Johnson
    on Jan 26 2012 17:12 PM
    Prodigy30 points
    I am using LM5088, 60Vin,  44Vout, Max 4.5A, Min 0A.  The output is unstable at light / no load.  I need to have regulated voltage at full range of current.  How can the LM5088 output be stabilized during hysteretic "pulse skipping" mode?
    Report Abuse
    • Reply
  • EricLee1880267
    on Jan 26 2012 18:03 PM
    Expert5320 points
    Pulse skipping operation at no load does not mean "Unstable".
    You can minimize the pulse skipping operation by adding a dummy load, using smaller inductance of inductor, lowering bandwidth.
    Due to its large difference between reference voltage(1.205V) and target output voltage (44V), any small perturbation due to a noise on feedback path will be amplified at the output.
    LM5088
    Report Abuse
    • Reply
  • Roger Johnson
    on Jan 26 2012 21:26 PM
    Prodigy30 points
    Unstable because output voltage 14V p-p or more at low / no load.  Also mean output voltage only 31V.  Large enough dummy load solves the problem, but at a price.  PCB layout was careful to isolate all analog circuits from high current switching noise.  Tried decreasing output capacitance.  Mean output voltage closer to 44V, but Vp-p still too large.  Am beginning to think that LM5088 unable to achieve low / no current output @ 44V and 4.5A output @ 44V with same circuit and 1V p-p or less.  Do you know otherwise?
    Report Abuse
    • Reply
  • EricLee1880267
    on Jan 27 2012 09:48 AM
    Expert5320 points
    It is unstable and unregulated. Something is wrong. Share your schematic and board with your local TI engineer. We can help you to find what is wrong.
    LM5088
    Report Abuse
    • Reply
  • Roger Johnson
    on Jan 27 2012 12:54 PM
    Prodigy30 points
    That's easy.  It is the TI LM5088-1 Eval board.  I changed the feedback resistors to 66.5K and 1.91K for 44Vout.  I changed the output caps to 50V (same capacitances).
    I see regulation failure below 100mA load.  I am not testing above 500mA load,
    Perhaps you can give me contact information for the local TI engineer you refer to.
    Report Abuse
    • Reply
  • Tony Pham
    Posted by Tony Pham
    on Apr 11 2012 16:02 PM
    Prodigy50 points
    Hi Roger,
    Did you get the solution for your no load/light load operation?  I have the same issue with the LM5088-1 with Vout set for >27V and operate in no load.  Vout<27V seem very stable.
    Report Abuse
    • Reply
  • EricLee1880267
    on Oct 02 2012 18:05 PM
    Expert5320 points
    Hi
    Please refer http://e2e.ti.com/support/power_management/non-isolated_dcdc/f/196/t/217498.aspx
    Eric
    LM5088
    Report Abuse
    • Reply
  • Amey Kulkarni
    Posted by Amey Kulkarni
    on Feb 18 2013 09:19 AM
    Prodigy30 points
    Hello;
       I am using LM5088Q-1 for of our application: Requirement is as follows:
    Vin= 6V(Cranking) to 36V
    VOut=5.7V
    I.Load=0.1A to 2.5A
    I did try to simulate the circuit in TINA.There were two things which I am not sure about.
    1> At low input voltage(6V) I did not see the frequency shift(DFC) To achive High duty cycle and Output did go below 5.7V.
    2> At Light Load IL=100mA or less  Output voltage  rose above set voltageof 5.7V and went around 7V and above.
    Please let me know if the issue is with the I.C. or with T.I.N.A Simulation.
    Waiting for your reply.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
