Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » Power Management » Power Interface » Power Interface Forum » TPS2459 Hot Swap
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 5 Replies
  • 2 Subscribers
  • 275 Views
  • Posted3 months ago
Options
  • Subscribe via RSS
Tags
  • 12V battery voltage monitor supervisor load disconnect
  • 802.3at
  • atca telecom -48V or
  • buck
  • CDP
  • charging
  • current limit
  • current limited
  • D0/D1
  • data path
  • FAULT
  • Fault prior to current limit
  • Flyback
  • GND pin
  • High Voltage
  • HOTSWAP
  • HOTSWAP TPS2493
  • HPA107
  • IN1
  • IN2
  • ipad
  • IPC Standards
  • IRF540NS
  • Li-ion
  • LM2575
Forum - Title
TPS2459 Hot Swap
Power Interface
Power Interface
Welcome to the Power Interface Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Forum
  • Files
  • Design Notes
New Post
TPS2459 Hot Swap
This question is not answered
Ankit Kumar
Posted by Ankit Kumar
on Feb 8, 2012 10:35 PM
Prodigy140 points
Dear Sir,
In my design, there is a I2C backplane and 16 number of cards. Among these 16 cards, there are 12 general purpose I2C cards, dual redundant Power supply cards and dual redundant controller cards. Before each slot on backplane, i am using TPS2459 whose inrush current limit, operating current limit and other parameters can be set using I2C bus
But i am facing one problem as follows:
The controller card can control the TPS2459 using I2C bus and take care of the 12 general purpose I2C card and Power supply card slots.
"But for the controller card hot swap, I will not have access to the I2C bus itself.  How to take care of inrush current and other parameters of controller card's power hot swap.
And could you please also tell me the minimum operating current that i can  have for 12V channel of TPS2459.
Thank you
HOTSWAP
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ankit Kumar
    on Feb 9, 2012 12:13 AM
    Prodigy140 points
    What i have thought is as follows:
    I will use a 2:1 master selector IC (PCA9541) and connect both the controller cards on I2C bus to this IC. This IC receives I2C lines from both the controller and routs only one
    I2C bus at output.
    " Suppose if one controller card is removed or inserted to backplane, other controller card will take care of the inrush currents, operating current limits by controlling TPS2459 at the slot of card being inserted"
    Please tell me whether it will be ok to do like this.
    thank you,
    ankit
    HOTSWAP
    Report Abuse
    • Reply
  • Eric Wright
    Posted by Eric Wright
    on Feb 11, 2012 11:00 AM
    Genius14275 points
    Your method seems to be sound. TPS2359 must be configured via the I2C bus.
    Report Abuse
    • Reply
  • Ankit Kumar
    on Feb 12, 2012 12:03 AM
    Prodigy140 points
    Thanks a lot for the confirmation.
    Could you please tell me, the minimum operating current for 12V channel. There is no information in datasheet. I am planning to have the following design parameters for 12V channel:
    12V CHANNEL:
    • RSENSE = 0.005 OHM
    • RSUM = 6180 OHM
    • OPERATIONAL CURRENT LIMIT = 250mA.
    I am going to set operating current limit as 5% of the inrush current limit. SO
    • INRUSH CURRENT LIMIT *0.05 = OPERATIONAL CURRENT LIMIT.
    (implemented by having  R3 FIRST BIT SET)
    • SO INRUSH CURRENT LIMIT = 250/0.05mA = 5A
    • So RSET = (5*0.005*6180)/ 0.675 = 230 OHM
    I request you to verify.
    Report Abuse
    • Reply
  • Eric Wright
    on Feb 13, 2012 10:10 PM
    Genius14275 points
    Your settings look good. There is no minimum 12V channel current (ie you can operate the channel with no load)
    Report Abuse
    • Reply
  • Ankit Kumar
    on Feb 13, 2012 10:48 PM
    Prodigy140 points
    Dear Eric Wright,
    Thanks a lot for your confirmation.
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
