I designed a board with 4 TPS25942L devices. They are not available through distribution yet and I can't order enough samples for my prototype build.
Can anyone estimate when they might be available through distribution?
Try the TI sample request through the TI web page. I'm told that the product distribution center has stock. You might get a backorder message, but be patient as your order will get filled.
By the way, this is a technical forum and we don't normally answer questions about IC availability (I happened to be working with the product engineer and was able to get the information above).
Good luck!
