[ TPS2546 ] Production Test Procedure
My customer has been considering the any of good ways to check whether TPS2546 works correctly or not.
Here is little background, my customer is going to use TPS2546 with CDP mode (1111) in conjunction with microcontoroller which receive high speed signals (D+/D-) via TPS2546.
In their system, they don't use STATUS pin, so actually not many ways to check by which mode the system is detected by portable equipment connected. It's assumed that the only way is to measure the charge current externally.
What they would like to figure out is the way to check TPS2546 work correctly from out side of system in simple way. it's really helpful, if you can share some kind of ideas which can be used for their production test as well.
Please let me know, if my statement is not clear.
