I am going to use TPS25200 in my motor drive circutry in order to limit current and also sense stall of dc motor.
The problem is MCU(digital) and motor driver parts' power systems are isolated.
Which GND should i use for pull down resistors?
Another question is, i will drive enable pin from an I/O of MCU. Do i need pull-up resistor at Enable pin?
Thank You.
