pls suggest alternative part no for the following components in EVM
1. C5, C6 22 μF Capacitor, Aluminum, 100V, ±20% 8×10.2mm EEVFK2A220P Panasonic
2. C14 22 μF Capacitor, Aluminum, 25V, 20% 5×5.8mm EEVFK1E220R Panasonic
thanks
thanks
Hi Venu,
You can use any aluminum electrolytic with 100V/25V and 22uF capacitance. Below are but a few examples looking at digikey.
Compare Parts | Image | Digi-Key Part Number | Manufacturer Part Number | Manufacturer | Description | Quantity Available | Unit Price USD | Minimum Quantity | Packaging | Series | Capacitance | Tolerance | Voltage Rating | ESR (Equivalent Series Resistance) | Lifetime @ Temp. | Operating Temperature | Type | Applications | Ripple Current | Impedance | Lead Spacing | Size / Dimension | Height - Seated (Max) | Surface Mount Land Size | Mounting Type | Package / Case | |
493-2109-2-ND | UWX1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 2,000 - Immediate | 0.07266 | 1,000 | Tape & Reel (TR) Alternate Packaging |
WX | 22µF | ±20% | 25V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 42mA | - | - | 0.248" Dia (6.30mm) | 0.213" (5.40mm) | 0.260" L x 0.260" W (6.60mm x 6.60mm) | Surface Mount | Radial, Can - SMD | |||
493-2109-1-ND | UWX1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 3,007 - Immediate | 0.33000 | 1 | Cut Tape (CT) Alternate Packaging |
493-2109-6-ND | UWX1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 3,007 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
493-2186-2-ND | UWT1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 4,000 - Immediate | 0.07790 | 1,000 | Tape & Reel (TR) Alternate Packaging |
WT | 22µF | ±20% | 25V | - | 1000 Hrs @ 105°C | -55°C ~ 105°C | - | General Purpose | 38mA | - | - | 0.248" Dia (6.30mm) | 0.213" (5.40mm) | 0.260" L x 0.260" W (6.60mm x 6.60mm) | Surface Mount | Radial, Can - SMD | |||
493-2186-1-ND | UWT1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 4,722 - Immediate | 0.33000 | 1 | Cut Tape (CT) Alternate Packaging |
493-2186-6-ND | UWT1E220MCL1GB | Nichicon | CAP ALUM 22UF 25V 20% SMD | 4,722 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
565-2217-2-ND | EMVE250ADA220MF55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 16,000 - Immediate | 0.08360 | 1,000 | Tape & Reel (TR) Alternate Packaging |
Alchip™ MVE | 22µF | ±20% | 25V | - | 1000 Hrs @ 105°C | -40°C ~ 105°C | - | General Purpose | 44mA | - | - | 0.248" Dia (6.30mm) | 0.205" (5.20mm) | 0.260" L x 0.260" W (6.60mm x 6.60mm) | Surface Mount | Radial, Can - SMD | |||
565-2217-1-ND | EMVE250ADA220MF55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 16,011 - Immediate | 0.35000 | 1 | Cut Tape (CT) Alternate Packaging |
565-2217-6-ND | EMVE250ADA220MF55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 16,011 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
565-2101-2-ND | EMVA250ADA220ME55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 6,000 - Immediate | 0.07980 | 1,000 | Tape & Reel (TR) Alternate Packaging |
Alchip™ MVA | 22µF | ±20% | 25V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 41mA | - | - | 0.197" Dia (5.00mm) | 0.205" (5.20mm) | 0.209" L x 0.209" W (5.30mm x 5.30mm) | Surface Mount | Radial, Can - SMD | |||
565-2101-1-ND | EMVA250ADA220ME55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 7,010 - Immediate | 0.34000 | 1 | Cut Tape (CT) Alternate Packaging |
565-2101-6-ND | EMVA250ADA220ME55G | United Chemi-Con | CAP ALUM 22UF 25V 20% SMD | 7,010 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
399-6677-2-ND | EDK226M025A9GAA | Kemet | CAP ALUM 22UF 25V 20% SMD | 12,000 - Immediate | 0.08295 | 1,000 | Tape & Reel (TR) Alternate Packaging |
EDK | 22µF | ±20% | 25V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 55mA | - | - | 0.248" Dia (6.30mm) | 0.222" (5.64mm) | 0.260" L x 0.307" W (6.60mm x 7.80mm) | Surface Mount | Radial, Can - SMD | |||
399-6677-1-ND | EDK226M025A9GAA | Kemet | CAP ALUM 22UF 25V 20% SMD | 12,180 - Immediate | 0.38000 | 1 | Cut Tape (CT) Alternate Packaging |
399-6677-6-ND | EDK226M025A9GAA | Kemet | CAP ALUM 22UF 25V 20% SMD | 12,180 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate |
493-6199-2-ND | UUX2A220MNL6GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 8,500 - Immediate | 0.16120 | 500 | Tape & Reel (TR) Alternate Packaging |
UX | 22µF | ±20% | 100V | - | 2000 Hrs @ 105°C | -55°C ~ 105°C | - | General Purpose | 121mA | - | - | 0.315" Dia (8.00mm) | 0.413" (10.50mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
493-6199-1-ND | UUX2A220MNL6GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 8,990 - Immediate | 0.56000 | 1 | Cut Tape (CT) Alternate Packaging |
493-6199-6-ND | UUX2A220MNL6GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 8,990 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
493-6433-2-ND | UCD2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 3,500 - Immediate | 0.26524 | 500 | Tape & Reel (TR) Alternate Packaging |
CD | 22µF | ±20% | 100V | - | 2000 Hrs @ 105°C | -55°C ~ 105°C | - | General Purpose | 130mA | 1.3 Ohm | - | 0.315" Dia (8.00mm) | 0.413" (10.50mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
493-6433-1-ND | UCD2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 4,002 - Immediate | 0.87000 | 1 | Cut Tape (CT) Alternate Packaging |
493-6433-6-ND | UCD2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 4,002 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
565-2160-2-ND | EMVA101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 6,000 - Immediate | 0.27930 | 500 | Tape & Reel (TR) Alternate Packaging |
Alchip™ MVA | 22µF | ±20% | 100V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 90mA | - | - | 0.315" Dia (8.00mm) | 0.394" (10.00mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
565-2160-1-ND | EMVA101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 6,160 - Immediate | 0.92000 | 1 | Cut Tape (CT) Alternate Packaging |
565-2160-6-ND | EMVA101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 6,160 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
493-7448-2-ND | UUR2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | 0.17580 | 500 | Tape & Reel (TR) Alternate Packaging |
UR | 22µF | ±20% | 100V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 100mA | - | - | 0.315" Dia (8.00mm) | 0.413" (10.50mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
493-7448-1-ND | UUR2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 1,920 - Immediate | 0.62000 | 1 | Cut Tape (CT) Alternate Packaging |
493-7448-6-ND | UUR2A220MNL1GS | Nichicon | CAP ALUM 22UF 100V 20% SMD | 1,920 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
565-2275-2-ND | EMVE101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 500 - Immediate | 0.27930 | 500 | Tape & Reel (TR) Alternate Packaging |
Alchip™ MVE | 22µF | ±20% | 100V | - | 2000 Hrs @ 105°C | -40°C ~ 105°C | - | General Purpose | 100mA | - | - | 0.315" Dia (8.00mm) | 0.394" (10.00mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
565-2275-1-ND | EMVE101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 1,111 - Immediate | 0.92000 | 1 | Cut Tape (CT) Alternate Packaging |
565-2275-6-ND | EMVE101ADA220MHA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 1,111 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
565-2341-2-ND | EMVH101ADA220MJA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 500 - Immediate | 0.35460 | 500 | Tape & Reel (TR) Alternate Packaging |
Alchip™ MVH | 22µF | ±20% | 100V | 550 mOhm | 2000 Hrs @ 125°C | -40°C ~ 125°C | - | General Purpose | 115mA | - | - | 0.394" Dia (10.00mm) | 0.394" (10.00mm) | 0.406" L x 0.406" W (10.30mm x 10.30mm) | Surface Mount | Radial, Can - SMD | |||
565-2341-1-ND | EMVH101ADA220MJA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 1,480 - Immediate | 1.11000 | 1 | Cut Tape (CT) Alternate Packaging |
565-2341-6-ND | EMVH101ADA220MJA0G | United Chemi-Con | CAP ALUM 22UF 100V 20% SMD | 1,480 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
338-2162-2-ND | AFK226M2AF24T-F | Cornell Dubilier Electronics (CDE) | CAP ALUM 22UF 100V 20% SMD | 500 - Immediate | 0.44540 | 500 | Tape & Reel (TR) Alternate Packaging |
AFK | 22µF | ±20% | 100V | 1.3 Ohm | 2000 Hrs @ 105°C | -55°C ~ 105°C | - | General Purpose | 97.5mA | 1.3 Ohm | - | 0.315" Dia (8.00mm) | 0.402" (10.20mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
338-2162-1-ND | AFK226M2AF24T-F | Cornell Dubilier Electronics (CDE) | CAP ALUM 22UF 100V 20% SMD | 746 - Immediate | 1.31000 | 1 | Cut Tape (CT) Alternate Packaging |
338-2162-6-ND | AFK226M2AF24T-F | Cornell Dubilier Electronics (CDE) | CAP ALUM 22UF 100V 20% SMD | 746 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
1189-2383-2-ND | 100SEV22M8X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | 0.25498 | 500 | Tape & Reel (TR) Alternate Packaging |
SEV | 22µF | ±20% | 100V | - | 2000 Hrs @ 85°C | -40°C ~ 85°C | - | General Purpose | 130mA | - | - | 0.315" Dia (8.00mm) | 0.413" (10.50mm) | 0.327" L x 0.327" W (8.30mm x 8.30mm) | Surface Mount | Radial, Can - SMD | |||
1189-2383-1-ND | 100SEV22M8X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | 0.84000 | 1 | Cut Tape (CT) Alternate Packaging |
1189-2383-6-ND | 100SEV22M8X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
1189-2386-2-ND | 100SGV22M10X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | 0.31274 | 500 | Tape & Reel (TR) Alternate Packaging |
SGV | 22µF | ±20% | 100V | - | 2000 Hrs @ 105°C | -40°C ~ 105°C | - | General Purpose | 90mA | - | - | 0.394" Dia (10.00mm) | 0.406" (10.30mm) | 0.406" L x 0.406" W (10.30mm x 10.30mm) | Surface Mount | Radial, Can - SMD | |||
1189-2386-1-ND | 100SGV22M10X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | 1.03000 | 1 | Cut Tape (CT) Alternate Packaging |
1189-2386-6-ND | 100SGV22M10X10.5 | Rubycon | CAP ALUM 22UF 100V 20% SMD | 1,000 - Immediate | Digi-Reel® | 1 | Digi-Reel® Alternate Packaging |
SGV | 22µF | ±20% | 100V | - | 2000 Hrs @ 105°C | -40°C ~ |
