Hi Darwin,
We have discussed TPS23753 PoE circuit before.
I have a thermal event and need confirm it with you.
Please see attachment of schematic that I provided to you two months ago.
I found R195 (10Ω 1% 0805) is about 80 degree C when system run in 8 watt.
It is hot point. Is it okay for the resistor? I also found the other EVM use 49.9Ω, should I change the vale from 10Ω to 49.9Ω or other values?
Thanks for your help!
Sincerely,
Jefer
