Could you tell me about TPS2553 programming the current-Limit?
Calculation result are different from Table2.
What is the difference?
TPS2553 about Ilim.pdf
Could you give me your advice?
Yusuke/Japan Disty
Yusuke/Japan Disty
Hi Yusuke,
Current limit threshold expression will be affected by temperature as mush as RILIM value is affected by this temperature and that's why we recommend 1% RILIM resistor to be used in order to ensure stability within the internal regulation loop, but the current limit threshold expressions used in TPS2553 datasheet account for current tolerance due to variation caused by temperature and process and no need for correction as long as the device is operating within the recommended operation conditions.
Haidar
Please consider checking the "Verify Answer" button if I've answered your question.
